-   -   Shower shut off (http://www.diychatroom.com/f7/shower-shut-off-19972/)
mark942 04-15-2008 02:28 PM
Shower shut off
Hi
I just installed a new Kohler shower and Tub faucet with a new mixing manifold.No leaks :thumbsup:
But my shower will not shut completely off when I am running just the tub water.The shower on/off is located on the bath faucet.Did I do some thing wrong ?
Thank you in advance for any information.
Cajun1 04-15-2008 08:48 PM
Your pipe between your manifold and shower head is either too small or has a blockage in it.
mark942 04-16-2008 03:16 AM
New 1/2 inch Pex. No blockage. I have put a couple of these together and have never had this happen.
Thank you for the reply.
Gencon 04-16-2008 06:14 AM
The water pressure in this house may be higher than in the other ones you've done. 1/2" PEX ID is smaller than 1/2" copper ID and may be creating enough restriction that its forcing excess pressure up to the head.
mark942 04-16-2008 06:44 AM
Thank you Cajun1 & Gencon......................:thumbsup:
I guess I will give copper from the manifold to the shower a try.Just made the switch from copper to Pex,like I said never had troubles before. I am running 60 pounds @ well inlet.Didn't realize Pex diameter was smaller than copper. I knew the fittings were on the small side though.Learn some thing new every day. Thank you again.
Termite 04-16-2008 01:33 PM
I'd start somewhere a lot more simple than the pipe sizing. 1/2" pex should be just fine at that pressure and for a single showerhead/tub diverter, and shouldn't cause you any problems. I see that done all the time.
You might want to try a new diverter (faucet). The little "gate" in there might not be seating. That's how you're probably transitioning from the shower head to the diverter and vice-versa. Buy a cheap one (or take the one you have back and get a replacement), put it on, and see if you have the same problem.
mark942 04-16-2008 05:03 PM
Replace the diverter seems a easier start.Guys @ the local plumbing store know me on a first name basis now............:laughing:
Thank You
