Shower Rough In Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2013, 07:12 PM   #1
bryanp22's Avatar
Rewards Points: 290
Shower rough in valve
Hi,
Has anyone used sharkbite connectors for a shower rough in valve? I have copper solidered connections right now and seems like this would be ideal instead of a torch that close to my framing. Anyone have a reason not to use them on the valve? I was going to get a Kohler rough in valve where the connections to the rough in valve are threaded.
bryanp22 is offline   Reply With Quote
Old 06-19-2013, 07:27 PM   #2
Rewards Points: 13,472
Better yet use Shark bite ball valves instead of the couplings.
And leave an access door.
Old 06-19-2013, 07:59 PM   #3
DIY staff
Rewards Points: 7,174
They can be used for the water feed lines but not for the tub spout --they cause restriction and might cause the shower to dribble.
Old 06-19-2013, 08:26 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 994
Another sharkbite post,, last one was canned at 50 something replys
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
oh'mike (06-22-2013)
Old 06-24-2013, 09:20 PM   #5
bryanp22's Avatar
Rewards Points: 290
I'm surprised they can't be used for shower spout. Looking at my Kohler rough in valve I see the spout and the line to the shower head both have just a small hole coming out of the valve unlike the supply lines that are unrestricted.
Old 06-24-2013, 09:32 PM   #6
DIY staff
I've seen the results--and read it here often enough to know--do not use shark bite fittings for the spout--use either soldered copper or threaded pipe---
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Shower Spider Valve Outlet: Elbows, Braided, ?? yogi_bear_79 Plumbing 6 11-03-2011 10:44 AM
Can't Identify Shower and Tub rough in valve stamped SHWR 7196 and TUB P-P USA help4diy Plumbing 1 11-21-2010 09:06 AM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 04:37 PM
