Shower Rough-in - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2013, 10:01 AM   #1
Shower Rough-in
Hello all, 1st post!
I ripped out my old shower, but kept the supply lines intact 1' off the floor. The stud wall is 2x4. I've finished up roughing in the new valve and shower head riser, but have come to realize a problem. The new valve is a lot thicker than the previous and sticks out into the shower 1-3/4" (The blocking behind is 1/4" off the back wall, plus the 2x4). They ran the supply lines really close to the shower-side of the bottom plate, unfortunately, so I'm kind of stuck as to the distance. I'm considering using a combination of 45-straight-45 fittings to bring the supply lines further into the stud bay. Opinions? Thoughts? Thanks!!
Matt
Wannabe209 is offline   Reply With Quote
Old 04-11-2013, 10:21 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
You're right. Offset the pipes as needed to fit the valve to the finished wall
You will have to change the block as well- perhaps a 1x? Will work
The Following User Says Thank You to TheEplumber For This Useful Post:
Wannabe209 (04-11-2013)
Old 04-11-2013, 10:29 AM   #3
Awesome, thanks. I'd put an elbow in to make it easy, but it needs to come in further than that. I'd planned on pulling the blocking already and conveniently have a 1x in the basement just itching to get used.
One more question, the shower head coupling currently would sit flush with the stud face...Since I'm pulling the whole valve assembly in, how far can that coupling sit behind the wall? If I pull it in another 1-3/4", it'll be sitting about 2-3/4" behind finished tile.. Thanks!
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 10:20 AM
Frameless Glass Shower Install lynxpilot Kitchen & Bath Remodeling 12 10-23-2012 11:14 PM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
