Shower Re-plumb - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2013, 02:17 PM   #1
Trucon01's Avatar
Rewards Points: 510
Shower re-plumb
Hi All,
I need to move the drain line for the shower about 5-6 inches toward the front wall. Is this as simple as cutting the existing ABS before the trap and re-doing it?
Any pointers would be greatly appreciated!!
Thanks,
Jeff
Shower re-plumb-photo-3.jpg   Shower re-plumb-photo-2.jpg   Shower re-plumb-photo-1.jpg
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 03-07-2013, 04:35 PM   #2
DIY staff
Rewards Points: 7,174
Where is it going?
You mentioned a front wall but I don't know where that is---
P-trap should be directly below the riser pipe---notched joist needs fixing---
Old 03-07-2013, 05:55 PM   #3
Trucon01's Avatar
Rewards Points: 510
in the pictures, my back is to the front wall. I can sister the joist once I have a plan of action.
Old 03-07-2013, 06:23 PM   #4
Trucon01's Avatar
Rewards Points: 510
OK, so I see now why they did it this way. In the attached pic, on the left side of the joist is the ceiling for the bathroom downstairs (which is lowered) and on the right is the ceiling near the front door (which is higher)...
Now the question, do I
A.
Re-do the plumbing as it is and use my current center drain pan
OR
B.
Plumb it the correct way and use a pan that has a front drain? If I go this route, the drain would have to be in the back because the shower wall is to the right in the pic.
Old 03-07-2013, 06:48 PM   #5
DIY staff
I see the problem,too---the only place for the P-trap is in that lowered soffit area---
Are you planning to use a premade pan or build your own?
Let's see what a licensed plumber has to say---I can't see a legal way to plumb that----
Old 03-07-2013, 06:51 PM   #6
Trucon01's Avatar
Rewards Points: 510
I already have a 34 x 48 pre-made FG pan with a center drain. Lowes has one with a LEFT drain that I could use. But would this look stupid to have a shower head on one end and the drain behind you?
Old 03-07-2013, 06:56 PM   #7
DIY staff
Centered always looks best to me----Let's see if Alan, EPlumber or one of the other plumbers have time to comment-- That offset 45* riser pipe might meet code---I just don't know---
Old 03-07-2013, 07:10 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 542
45 degrees from vertical is still defined as vertical by code. So if you can hit the drain using a 45 offset- thats how you should proceed.
The problem with a horizontal run is that it collects scum and such- that leads to odors, etc.
As for the drain location- I'd get it over the ptrap- how it looks is subjective.
Personally, I really don't like standing on a shower grate. I would like off center as long as the floor is sloped to it
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 10:20 AM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
Where "exactly" does the shower pan Membrane go? remodelin'girl Plumbing 1 01-16-2010 05:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
