Old 07-25-2009, 01:24 PM   #1
shower problem
Hi
I have a problem with my shower
I attached a picture to show you how it is made
I cant get any cool water its just scalding hot
no matter how i turn the back handle its still hot
what could this be?
I took it apart and cleaned the cartridge
it had a bunch of black grease looking stuff but it didnt help
do you think it could be the cartridge?
it turns on and off ok but it the temp just dont change its wide open hot unless you cut the water almost off its bareable hot but the longer its on the hotter it gets
thanks so much
Christopher
rebelbull is offline   Reply With Quote
Old 07-25-2009, 03:03 PM   #2
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation
shower problem
THAT IS A MIXET VALVE
YOU DO NOT EVER NEVER CLEAN AND REINSTALL A CARTRIDGE ! !
YOU ALWAYS INSTALL A "BRAND" NEW CARTRIDGE
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Old 07-25-2009, 09:02 PM   #3
shower problem
ok so is the mixet valve that cartridge?
do i just change that or is it farther in the pipes
also whats the proper way to take it out I just unscrewed it
hope thats right it all unscrewed out
Old 07-25-2009, 09:30 PM   #4
MACPLUMB's Avatar
Exclamation
shower problem
YES THAT IS ALL THERE IS TOO IT !
More On This Topic
Hey everybody, Don Golden for Expert Village and let's move on with the shower project. We've just taken off the valve and now I want to show you the real crucks of our problem is right here. This is called your water cartridge and this is right here, is... Read More »
We are going to talk a little bit about how we are going to get water to our shower, our toilet, our new washing machine, and our sink. What I had to do was I had to find a place where I could pull cold water and also pull hot water and being that these... Read More »
Faucets should accentuate the overall appearance of your bathroom. You can choose from a large selection available at hardware stores, home centers, bath remodeling showrooms and plumbing wholesalers. You can also shop online. Whether you are replacing... Read More »
With today's busy schedules, it's difficult to find time to relax and pamper yourself. But you don't have to go to a vacation resort to feel spoiled. By installing a multi-head shower, you can turn your own shower into a mini-spa. Read on to learn how to... Read More »
Welcome back to Expert Village. I'm Chef Donno. We have our turkey in the oven. It's been cooking for about an hour and fifteen minutes. So let's check the temperature. We're looking for 165 or better. So, we'll check the temp. It looks good, looks ready... Read More »
Rotting shower walls PICTURE Sarah24 Kitchen & Bath Remodeling 6 05-10-2009 01:09 AM
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 02:47 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 03:36 PM
Shower floor slope Not Sure Building & Construction 11 06-10-2008 12:12 PM
shower hot water problem ajoantmug Plumbing 5 01-21-2008 05:39 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
