Old 10-14-2012, 12:11 PM   #1
shower problem
What is the problem when my shower fluctuates from hot to cold and back to hot again?
Brando82 is offline   Reply With Quote
Old 10-14-2012, 12:16 PM   #2
shower problem
The problum is it's uncomfortable to shower after that.
Or it could be the anti scald valve needs to be cleaned out because there's some trash in it.
Every company designs there's differant so you may have to first figure what brand you have then go on line to see how to fix it.
Old 10-14-2012, 12:20 PM   #3
shower problem
The most obvious cause is a water heater that is too small coupled with not being first in line to take a shower.
retired guy 60 is offline   Reply With Quote
Old 10-14-2012, 12:41 PM   #4
Master General ReEngineer
Bondo's Avatar
shower problem
Ayuh,.... Somebody flushed the toilet,..??
Old 10-15-2012, 01:48 AM   #5
747
registered
747's Avatar
shower problem
Antiscalding value needs to be replaced.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
oh'mike (10-15-2012)
Shower drain problem SUPPO Plumbing 5 02-05-2012 12:04 AM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Shower curtain rod problem edta1 Building & Construction 5 05-20-2011 04:23 PM
Hot/Cold water problem in shower 8thebroker8 Plumbing 8 06-30-2010 07:12 PM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 01:59 PM
