Old 10-06-2011, 12:02 AM   #1
Shower Problem
Well im having a shower pressure problem.. theres water to the top just fine but doesnt put pressure to the shower head when trigger is pulled.. what is going on?? where do i start?? thanks..
Yang7 is offline   Reply With Quote
Old 10-06-2011, 08:35 AM   #2
Super Moderator
Shower Problem
What brand of mixer do you have? Single handle or double?
Top of what?
Old 10-06-2011, 10:08 AM   #3
Plumb or Die!
Shower Problem
Of the bajillion times I've seen or heard of this problem, it's due to the low flow design of the shower head 99% of the time. Very often, if you unscrew the shower head from the chrome elbow sticking out of the wall, you will see a removable washer. That's a flow restrictor, looks like a normal washer with a small hole for the water to get through. Pull it out and it's all good. Often they're an add on, pull them and chuck 'em, but if they're neccissary to seal the head to the elbow, you'll need another washer that isn't a flow restrictor.
In the case of a "telephone shower" head, these are located at the shower head end of the hose.
plumber666 is offline   Reply With Quote
The Following User Says Thank You to plumber666 For This Useful Post:
josall (10-06-2011)
Old 10-06-2011, 11:59 AM   #4
Shower Problem
I've checked and there's no restrictor, completely hollow. It is a 2 handle.. not sure what brand..
Old 10-06-2011, 04:57 PM   #5
Super Moderator
Shower Problem
Did you turn it on with the shower head removed?
Old 10-06-2011, 08:44 PM   #6
Shower Problem
you said this is 2 handle you must have lift spout ...when you lift spout to divert to shower does water still come out of tub spout.....if is does you may need to replace lift spout?
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 09:03 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Shower curtain rod problem edta1 Building & Construction 5 05-20-2011 04:23 PM
Hot/Cold water problem in shower 8thebroker8 Plumbing 8 06-30-2010 07:12 PM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 01:59 PM
