Old 06-04-2012, 03:13 PM   #1
Shower pressure problem
The water pressure in the shower has been weak for the past few weeks. The water pressure from the bath faucet however is normal. I have a specific faucet with a shower switch. when I turn the water on and pull the shower switch up the pressure is ok but after just a few minutes it becomes weak. I noticed that if I push the switch down (the water switches to faucet when the switch is down) then pull it up again the shower pressure goes back to normal, then again becomes weak in a few minutes. If I keep doing the switch thing (switching to faucet then to shower again) the shower pressure is fixed only for a couple of minutes. I do notice brownish color has formed on the shower head.
I was wondering if it's the shower head causing it and needs to be replaced or if it's the water mixer (switch mechanism) is broken and needs replacement.
Here is a picture
http://s1062.photobucket.com/albums/t483/roseteaberry/
roseberrytea is offline   Reply With Quote
Old 06-04-2012, 09:09 PM   #2
Super Moderator
Unscrew the shower head and clean the filter screen--it's usually built into the rubber washer (like a garden hose)
Some people even enlarge the hole with a drill bit---but that violates some law or other--so if you do that look out for the shower head police---
Strange pressure switch problem jones814 HVAC 24 01-16-2012 11:24 AM
Lose water pressure in shower when turning down temperature rdblatch Plumbing 1 09-07-2011 08:53 AM
Water pressure, gallon per minute values in relation to shower output JasonNY Plumbing 7 12-23-2010 06:50 PM
Home water pressure problem ATLdrew Plumbing 13 04-24-2009 12:17 PM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
