Shower Pressure Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2013, 11:05 AM   #1
Hello:
I am working on installing a new shower and I ran into a pressure issue. The hot and cold water supplies are 1/2" copper pipes and delivering 80-85 PSI to the valve (Luxart 401) which connects to a tub spout and 3-Way Diverter Valve, then it connects to a Hand Shower and a Rainfall shower.
If I set the diverter valve to just the hand shower I only get 55 PSI, if I set the Diverter to the Rainfall shower and hand shower the PSI drops to 20 at the handshower, while rainfall shower seems keeps good pressure.
Any ideas what may be causing the issue? Thanks for your help!
Jefferx is offline   Reply With Quote
Old 01-19-2013, 11:19 AM   #2
Depending on the fixture and GPM requirements, you could need a 3/4" or even 1" supply for hot and cold. Its the volume of water that will be an issue. Read the manufacturers specs
BC Plumber is offline   Reply With Quote
Old 01-19-2013, 05:56 PM   #3
Both valves have 1/2" inputs, both fixtures are 2.5 GPM, figured 1/2 supplies could handle that.
Old 01-19-2013, 06:21 PM   #4
Roofmaster
Rewards Points: 2,172
You did not solder on the valve did you? Just asking to eliminate possibilities.
Old 01-19-2013, 09:19 PM   #5
Rewards Points: 13,446
A 3/4" supply can supply almost double the CFM of a 1/2 line.
It's lack of flow not pressure your dealing with I'd bet.
http://www.plumbingsupply.com/flow_c...for_pipes.html
Old 01-19-2013, 09:35 PM   #6
Removed the flow restrictor on the hand shower and it fixed the pressure issue. Thanks for the help.
Low water pressure in shower Bluew126 Plumbing 5 08-28-2012 06:47 PM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
Potential Water Issue in New Shower? cobrakai Kitchen & Bath Remodeling 4 02-12-2011 05:36 PM
Insane water pressure in shower!!! Sarah24 Plumbing 5 12-09-2008 05:27 AM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 08:07 PM
