Old 05-13-2012, 02:49 PM   #1
shower pressure doubled???
Hey guys,
Last night my shower pressure seems to have at least doubled on me. its only in my shower, and non of my other sinks/faucets have increased.
I have a Moen Set in my shower, its about 2 years old. I am not able to increase or decrease the pressure manually, its just set at a constant pressure, i can either turn it on, off or adust the hot/cold. I dont know if there is something inside the tap itself that regulates the pressure and it broke?? i really have no clue. More pressure seems like its not a bad thing, but its to much and the water is shooting off the walls and out of the tub. lol. any idea what the issue is and how i can fix it?????
thanks
codie is offline   Reply With Quote
Old 05-13-2012, 03:48 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Call the utility that you get water from, and have them do a pressure test. I know one year, they were working on the mains down the road, and our water pressure had increased, and a couple of days later, they finished the work, and the pressure went down to how it was before.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 05-13-2012, 05:01 PM   #3
There's nothing in a shower valve that can change the pressure. Only the flow from the hot and cold supplys is changed to prevent scalding.
Old 05-13-2012, 08:08 PM   #4
Sounds like the flow regulator in the showerhead failed. Try replacing the shower head.
What type/model showerhead do you have?
goosebarry is offline   Reply With Quote
Old 05-13-2012, 11:29 PM   #5
Maybe some one took out the water saver from the shower head. I do this all the time..I like taking a shower not like I am out side in the rain
ESCAMILLA is offline   Reply With Quote
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
Low hot pressure to power shower lazthemag Plumbing 2 02-21-2010 10:35 AM
Master bathroom shower pressure, weaker every day julielampp Plumbing 3 09-08-2009 08:33 PM
Low Water Pressure Delta Single Handle Shower Model 602 rckeagle Plumbing 2 07-24-2009 03:11 PM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 09:07 PM
