Shower Plumbing Questions From A Novice - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2012, 06:58 PM   #1
Post
Shower plumbing questions from a novice
Hello all,
I'm in the middle of a complete gut of our 2nd floor bathroom. The house was built in 1917, and judging by the decor, the upstairs was finished sometime in the 60s or 70s. This is my 2nd bathroom re-do (I did the first floor first), but I didn't have to do much in the way of plumbing the first time around.
I'd like to do as much of the plumbing as I can, but I'm fairly inexperienced. I'm looking to do a custom tile shower with 2 shower heads. The water supplies are 1/2" copper, and the current shower drain is 1 1/2" ABS. I have a fairly new water heater that has a first hour rating of 69 gallons.
Given the above specs for the pipes, drain, and water heater, will I be able to do 2 shower heads, or do I have to stick with one?
My other question is about the fittings and fixtures. How much of the shower plumbing can you build yourself? I saw a house once that had a tile shower with lots of exposed pipe and some industrial-looking gate valves. How difficult would it be to do this sort of thing? What do I need to know before tackling this? (Don't worry about dumbing it down too much )
Thanks in advance for any help.
slkarns is offline   Reply With Quote
Old 04-09-2012, 07:37 PM   #2
DIY staff
Rewards Points: 7,174
A double shower head will require 3/4" feed lines from the water heater and the cold line--
Shower drains need 2" pipe and a vent within five feet of the drain--1 1/2" vent.
My bookmarks have vanished---look through the tile section for a link to building a tiled shower base--
Old 04-09-2012, 09:17 PM   #3
Rewards Points: 13,690
By doing exposed industrial style plumbing plan on a lower resale value. I do not know anyone that would think that was a great idea.
Old 04-10-2012, 04:53 PM   #4
If I'm limited to one shower head, that's okay--I don't think I'm ready to replace the supply lines and drain.
As far as the exposed pipe and lowering the resale value, that's not really a concern. I've attached a photo of what I'm talking about. What's got me confused is, where is the valve to prevent scalding in this photo? Did they simply leave it out?
Old 04-11-2012, 06:05 AM   #5
DIY staff
That's interesting --but there is no way that meets code in the USA ---someones idea of rustic--no anti-scald--no pressure balancing--
Old 04-11-2012, 09:09 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I highly recommend upsizing that drain to 2" whether you're using 2 showerheads or not.
Tiling a shower is a lot of work, and if you cut a corner on something, chances are by murphy's law, you're going to have problems with that 'something'
The drain really needs to be 2".
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
oh'mike (04-11-2012)
Old 04-11-2012, 09:42 AM   #7
Rewards Points: 150
I'm onboard with everyone else here.
That drain needs to be 2" regardless of 1 or 2 shower heads.
If your going to tile, do your research. Use proper water proofing membranes. Go with a manufactured drain kit. It is a big investment and leaks are not an option.
As far as the industrial style valves and pipes, don't think it meets code.
psilva8 is offline   Reply With Quote
Old 04-11-2012, 09:28 PM   #8
Rewards Points: 636
irc states that a 1 1/2 drain can handle up to 5.7 gpm
http://publicecodes.citation.com/ico...2_7_sec009.htm
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Plumbing for shower and steam generator Smitny22 Plumbing 10 02-20-2012 05:19 PM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 09:12 PM
Outdoor shower questions dalepres Building & Construction 7 03-28-2011 06:10 PM
A few quick questions about redoing a shower Swazzle Remodeling 1 08-02-2010 10:06 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
