Shower Plumbing Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2011, 11:46 AM   #1
Shower plumbing issue
Hello everyone, I am new to this forum and looking for some advice. In my basement there is a bathroom partially finished. The problem I have is that the output line for the shower head comes out of the wall as a copper pipe with a cap on the end, about 6" long. Its not the 1/2" threaded female fitting recessed into the wall like its supposed to be.
I'm trying to find a solution for this rather than cutting through the wall? Like putting a 1/2" fitting on outside of the wall and using a deep flange to cover it?
ANY advice from the pros would be greatly appreciated
Thanks !!
mjllewellyn is offline   Reply With Quote
Old 03-15-2011, 11:58 AM   #2
Experienced
Jackofall1's Avatar
Hi and Welcome mjllewellyn, to the best dary DIY'r site on the web.
Is there no access from behind the shower? Cut it solder an adapter on and screw on your shower head.
Mark
Old 03-15-2011, 12:06 PM   #3
Thats the problem, its up against a concrete wall with the shower body already installed...
Old 03-16-2011, 08:15 AM   #4
Plumb or Die!
Are you sure the copper isn't a peice with a soldered cap on one end, and a male pipe thread adapter on the other end? Us plumbers often use a peice like that temporarily while a wall gets drywalled, etc., and remove it when putting the faucet trim on.
plumber666 is offline   Reply With Quote
Old 03-16-2011, 08:27 AM   #5
Yes I'm sure, I can see through the hole. Its a copper pipe run directly into an elbow.
Old 03-16-2011, 08:55 AM   #6
Well, if that's the case, then I'm sorry to say but you'll just have to open up the wall and redo it.
VIPlumber is offline   Reply With Quote
Plumbing Issue sportgoal53 Plumbing 3 10-20-2010 11:10 PM
Plumbing a shower. Proby Plumbing 4 08-08-2010 08:48 AM
Plumbing in the shower head obeans Plumbing 3 03-11-2009 03:08 PM
Shower Plumbing Ron Plumbing 1 08-15-2007 11:38 AM
Shower window issue help! Ducowti Building & Construction 2 05-26-2005 03:36 AM
