Shower Panels? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2012, 10:07 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
Shower Panels?
A while back you guys gave me some good advice on shower valves....(Delta and Moen being the top picks)
So....I'm looking....and comeing across shower panels....this is an example...
http://www.amazon.com/Vigo-Industries-VG08001-System-Shower/dp/B003D4W87S/ref=sr_1_4?s=kitchen-bath&ie=UTF8&qid=1345906579&sr=1-4&keywords=shower+panel+system
But they obviously don't have a Delta valve in them.
Who makes their valves? Are these good units?
I naturally tend to avoid the 'all in one' items....if one item fails, 'all' of it fails....
Advice? Experience?
Old 08-25-2012, 10:22 AM   #2
Rewards Points: 13,450
Do you have at least 3/4 supplys avalible to that area.
Going to need them to get enough flow.
Old 08-25-2012, 10:55 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 562
These types of panels are OK for upgrades to existing homes. I installed one similar a year ago. Owner purchased it through HD. We fed it with 1/2" supplies at a max 60psi(well) I wanted to go 3/4 but the owner did not want to pay.
She originally wanted a nice Moen set up but she couldn't meet the water demand. Vigo's website says 1/2 will supply that valve.
But, if I was in your shoes, I would not go this route. You have the chance to install a decent Moen, Delta, Grohe, etc. I wouldn't compromise. You'll be reminded of your choice every morning.
Old 08-26-2012, 10:14 AM   #4
JOATMON
ddawg16's Avatar
I haven't ran the supply yet.....I was going to run 3/4 up to a spot between the tub and shower...then split off to 1/2"......
I have some access issues....I'm concerned I can get a 3/4" up to the valve.
eplumber....I've also heard that Grohe is good....
Old 08-26-2012, 12:47 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
For a new shower installation I would never recommend putting something like this in.
It looks like an afterthought.
Journeyman Plumber
Old 08-26-2012, 12:53 PM   #6
Doing it myself
Alan's Avatar
Obviously something like this is an extra 1000 compared to what you have listed.....
http://www.us.kohler.com/us/Luxury-p...egoryId=431245
It will be more work to get it installed, but your finished product will end up being so much nicer, and i bet you will be happier too.
Once you get that stuff in the wall you have a name brand valve that isn't going to fail on you, and you can get parts for it later if you need to.
If you decide to go custom like this, i might steer away from delta, if i remember correctly, out of moen, delta, kohler, the delta valves are not available with a 3/4" inlet.
Journeyman Plumber
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 10:20 AM
No pressure in my shower loki993 Plumbing 6 08-08-2012 03:09 PM
3 phase panels and sub panels michael825 Electrical 32 08-31-2011 08:43 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
