Old 05-27-2009, 04:46 PM   #1
Question shower pan removal
We are trying to remove a shower pan. The house was built in 1960. We have removed all surrounding nails etc.,using digging bar prying (tools) etc pan will only raise up about 1to 2 inches. we have tried a tool to insert in the drain and try and turn that. Cant find a tool that fits and have exhausted that route. There seems to be lead(perhaps) poured in the drain(was told that was common to keep the pipe that meets the drain from leaking. Any ways we are at are wits end. tried going under the house there is so much heater ducting that you cant climb over and cant get under. If anybody out there could give us some advice it would surely help and would be very much appreciated. ( do ya think its connected under the pan to a pipe?) This is s.rog girlfriend asking cuz he is too busy to get to the puter I hope I've asked the right questions and explained our problem properly to hopefully find someone who knows. Thanks s.rog and girlfriend
s.rog is offline   Reply With Quote
Old 05-27-2009, 06:08 PM   #2
It probably is lead. If it is the drain holding it on you can dig out the lead with a small chisel and hammer. Myself, I would cut the shower pan apart with a reciprocating saw.
Rege
RegeSullivan is online now   Reply With Quote
Old 11-02-2009, 02:44 PM   #3
You have a lead and oakum poured joint. To remove a poured lead and oakum joint take a 3/8" drill bit and drill a few holes down past the lead and into the oakum.. Push a screwdriver under the lead ring and lever it up. Once it's free you can began to peel the lead ring out. Now pick out the oakum and you can pull the joint apart.
No special tools needed. Good luck.
Lee007 is offline   Reply With Quote
More On This Topic
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
Not only is mold unsightly, it can cause health problems. Mold grows in humid or damp areas of your house and will continue to grow unless removed. After removing the mold, you can prevent it from growing back with a few simple steps. Here are a few tips... Read More »
How to Drain Oil From Car
How to Drain Oil From Car by Expert Village
Next we are going to drain the oil from the vehicle by removing the drain plug which is an oil pan. It is best if you can use a socket so you don't strip the drain plug that can be pretty tight at times. I recommend us using a hand wrench, not an air... Read More »
How to Unclog a Sink Drain
How to Unclog a Sink Drain by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip I will be taking you through step to for making our sink drain better. Our next step is to remove this portion of that P trap to this I'm going to loosen both of these collars that holds the... Read More »
Hi, I'm Adolph Ramirez from Tampa, Florida and on behalf of Expert Village, today I'll show you how to clean a shower head. Okay, once the shower head is off, let's inspect the pipe. Make sure there's no corrosion on the inside. Make sure that the thread... Read More »
Damaged backer board during shower tiler removal, repairable? Bobster Building & Construction 2 10-06-2008 12:00 PM
old shower door removal pamelasue212 General Discussion 1 09-22-2008 08:31 PM
Removal of shower doors/frame proofer Plumbing 8 08-16-2008 12:33 PM
Suggestions - Old Stall Shower Floor Removal Rick Bruner Remodeling 0 03-23-2008 05:56 PM
glass shower door removal ross General Discussion 1 04-25-2005 08:22 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
