Shower Pan Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2013, 08:50 PM   #1
Unhappy
Shower pan removal
Having a problem getting the shower pan off of the drain I don't know whats holding it down. The shoe looks like it's threaded but there's no way to get a grip on it there's no slots or tools to use on the flat surface. I don't want to bust it off, I will be reusing it. I have to remove it to get the rotted sub floor out from under it. Help please
Janice28 is offline   Reply With Quote
Old 01-10-2013, 09:00 PM   #2
Rewards Points: 14,278
Some use a nut under the pan to hold it in place.
If not use one of these.
http://www.bing.com/images/search?q=...7854E&first=91
If it was mine I'd replace it, without that cross piece stiff can go down the drain.
Old 01-11-2013, 12:25 PM   #3
Roofmaster
Rewards Points: 2,210
Hay Joe, why are you shoving stiffs down the drain? What are you, a Mechanic?
Old 01-11-2013, 04:54 PM   #4
DIY staff
Rewards Points: 7,174
Janice---We need more info---post a picture---many can not be removed from above the pan and the ceiling below must be opened---the cost of a new pan might be less than the repair of the ceiling below---Just a thought---
Old 01-11-2013, 08:06 PM   #5
Roofmaster
The chances are pretty darn good that if the floor below the shower pan is shot from leaks, the back of the ceiling below is covered with black mold. In any event, repairing dry wall ceilings is cake. Sawsall time.
Help with shower pan removal - 1960s bath jm71 Kitchen & Bath Remodeling 6 11-23-2009 07:54 PM
shower knob removal mnemnoch Plumbing 1 03-02-2009 04:21 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
Removal of shower doors/frame proofer Plumbing 8 08-16-2008 10:33 AM
glass shower door removal ross General DIY Discussions 1 04-25-2005 06:22 AM
