Shower Pan Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2012, 07:20 PM   #1
Shower pan plumbing
I have an old shower I'm remodeling. It has a sloped concrete pan into a cast iron drain. It's in the basement so it's over concrete.
I want to tile the floor and walls, so I'm thinking of keeping the current pan, add a membrane, add another layer of sandy mortar.
I don't know what type of drain to use to go into the cast iron drain that will now be lower than the tiles and membrane.
Thanks in advance.
Joebgoody1 is offline   Reply With Quote
Old 11-09-2012, 09:52 AM   #2
Rewards Points: 254
You should cut out the cast iron past the p trap and replace with pvc piping. Then you can do your shower pan the way you want.
pwgsx is offline   Reply With Quote
Old 11-11-2012, 03:44 PM   #3
I decided to break the previous pan and see what the drain looks like. It's a 4" cast iron pipe sticking up about 2 inches from the ground. I'm trying to avoid cutting into the concrete foundation. Is there any easy options?
Old 11-11-2012, 04:23 PM   #4
DIY staff
Rewards Points: 7,174
That sounds very wrong---is there a P-trap under there? I;m guessing someone used an existing floor drain for the shower drain---
Short answer--no easy way----shower drains are typically 2 inch---and extend below the slab by a bit---
breaking out the old drain and P-trap is not advanced plumbing----we will walk you through it if you go that route---
Water issue in bathroom at base of the tub and shower plumbing wall NeverEnoughTime Plumbing 3 10-24-2012 11:23 PM
Can't access shower plumbing, need ideas. lowercaseletter Plumbing 3 03-07-2011 07:24 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Bathroom remodel. New Shower Plumbing s4alex Plumbing 5 10-14-2008 06:40 PM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 08:26 AM
