Old 06-17-2008, 12:38 PM   #1
Question
shower pan mud, what kind?
I have a 2nd floor bathroom that I want to put a tile floor. Since I have had problems with kids spilling lots of water and ruining the ceiling below and since I will have a washer/dryer up there now too, I installed a drain on the low spot of the floor and am treating the floor as a shower pan, with membrane, and metal lathe, now I am at the point where I need to put mud and perfect the slope to the drain. Will quickrete (No.1102) work for this purpose or do I use the Flexbond thin -set mortar that I was going to use to lay the tile down? I was recommended both for shower pans by different workers at the store.
Thanks,
-leadfoot
leadfoot is offline   Reply With Quote
Old 06-17-2008, 01:26 PM   #2
RippySkippy's Avatar
This is the day for mud pans ;-)
Check this out.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-17-2008, 04:54 PM   #3
Moderator
Termite's Avatar
Neither. The pan's mud should be a sand/portland mix. 3 parts clean sand, 1 part portland. You can buy it pre-mixed in dry bags at tile suppliers. You mix it to a very, very dry consistency (1 quart latex and 1 quart water per 80lbs. It is packed in place and screeded off. Looks and finishes nothing like normal concrete or thinset.
Old 06-17-2008, 04:56 PM   #4
Moderator
Termite's Avatar
That's a great article RippySkippy posted. And, it is written by a tile authority.
Looks like I wasted my money on latex additive, but it worked great!
The pics in that link really illustrate the consistency you're looking for.
Old 06-17-2008, 10:54 PM   #5
Doing it myself
Alan's Avatar
Just for the sake of being in the plumbing section..... did you get a trap primer on that floor drain?
Journeyman Plumber
Old 06-17-2008, 11:17 PM   #6
Moderator
Termite's Avatar
Good idea, but does he need one?
Old 06-18-2008, 12:36 AM   #7
Doing it myself
Alan's Avatar
My codebook says he does....
Floor drain or similar traps directly connected to the drainage system shall be provided with an approved automatic means of maintaining their water seals.
1007.1
Not sure if that is part of the UPC or an amendment, however..... but it's there.
Even if you don't need one to meet code, if it were mine, i'd do it anyway.
Journeyman Plumber
Old 06-18-2008, 10:01 AM   #8
Moderator
Termite's Avatar
I had to look that one up in the IRC/IPC. You're right, unless a deep seal trap is used. I learned something today! Thanks!
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 09:07 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 01:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 11:33 AM
