Shower Pan Membrane-install Advice - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2007, 05:41 PM   #1
Shower pan membrane-am I in wrong forum?, flooring/tiling maybe?
hey everyone,
need some advice, just finished working with a g/c who completed part of my basement renovation. He took me thru framing, electric rough-in and plumbing rough-in. Here's the issue, inspector won't pass plumbing until I install shower pan and he can test it. Fair enough, just not ready to finish this, bathroom was going to be last project.
Here's my question, when I install shower pan membrane will I need to install a barrier between concrete slab and membrane? Does membrane use adhesive to to adhere to the slab?
My DIY book is pretty good but doesnt mention slab as compared to subfloor installation.
Also, very generally, what will an inspector look for in a pan test?
Thanks guys.
Last edited by Mikedks; 06-12-2007 at 03:11 PM. Reason: no responses-wrong forum possibly?
Mikedks is offline   Reply With Quote
Old 06-15-2007, 11:09 AM   #2
Does anyone know anything about shower pans????
would much appreciate advice or guidance to some info.
Moderator?
Old 06-15-2007, 01:09 PM   #3
Longtooth's Avatar
Shower pans are critical. Since you mentioned membrane, it sounds like you are using tile for the floor. If so, DIY and you are headed for trouble.
A plumbing contractor is your best bet.
Understanding the physics of lath, mortar, tile and grout is also critical so do your homework before you start.
Contact a local waterproofer who specializes in Hot Mopped Shower Pans, make sure you have the proper shower drain for your application and the waterproofer will install it at the same time as the HMSP. Usually only slightly more than the membrane junk.
Or, go with a fiberglass or plastic shower pan, mortar bed installed.
Both installs are very important and the inspector will shoot you down if not properly installed.
Longtooth is offline   Reply With Quote
Old 06-17-2007, 02:58 PM   #4
Thanks for advice.
However...don't have the cash to hire a plumber to finish.
Yes, you are correct, it will be tile floor. The drain has already been installed by plumber and the concrete/cement has been poured and sloped correctly. As the shower is a custom size, prefab fiberglass won't work, not looking for that anyway.
Sorry for my ignorance, but is'nt hot mopping old school?, thought most plumbers/tilers had moved to membranes. Not in the budget anyway, I have to do it myself, no getting around it.
I know there are plumbers here, do you think Longtooth is correct and I would be over my head?
Old 06-17-2007, 03:35 PM   #5
Journeyman Plumber
Ron The Plumber's Avatar
Pan liners here have been taken over by the tile folks, even though it is in our code book. Since I don't get into them, I have no details to offer. Sorry
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-17-2007, 03:55 PM   #6
thanks anyway.
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 03:46 PM
Shower drain gasket install tricks dbrew Plumbing 6 03-10-2010 09:20 PM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Shower membrane mc52 Building & Construction 2 01-27-2007 09:59 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 06:17 PM
