Old 02-07-2011, 07:37 PM   #1
shower pan on concrete floor
I am building a basement shower on a concrete floor. I will put in first mortar base then liner then final concrete layer. Do I need mesh in either concrete layer?
Tobias is offline   Reply With Quote
Old 02-07-2011, 07:43 PM   #2
Tileguy
Bud Cline's Avatar
No!
What type of floor drain are you using and is the floor already sloped to a drain?
Old 02-08-2011, 09:26 AM   #3
I will use a proper 3 piece drain assembly. Floor is level, I was planning on sloping the first mortar base.
Old 02-08-2011, 09:37 AM   #4
Experienced
Jackofall1's Avatar
Heres a link to a great product to assist in making that shower pre-slope and final pan slope darn near perfect. I used this on my first shower pan done last year and couldn't have been more satisfied.
http://www.markeindustries.com/pre-pitch.html
Mark
Old 02-08-2011, 09:58 AM   #5
Super Moderator
This will give you the basics of pan construction---Shower Construction Info (a collection of posts) - Ceramic Tile Advice Forums - John Bridge Ceramic Tile
Old 02-08-2011, 06:58 PM   #6
Tileguy
Bud Cline's Avatar
Do yourself a favor and use the Schluter Systems floor drain and KERDI Mat waterproofing system.
Only one cement slope is required (no pre-slope) and you don't have to fight the pan liner to fit it to the studs and curb.
You will need one KERDI Drain, one small roll of KERDI Mat, one Schluter Curb, one small roll of KERDI Band. The KERDI Drain is much simpler to use.
Best system to come along, ever.
installing shower pan on a concrete floor sv9779 Remodeling 19 03-13-2011 11:03 AM
Help with shower drain install in concrete floor!! psychomti Plumbing 0 05-17-2010 02:54 PM
Damp Concrete Garage Floor Tom S. Building & Construction 15 03-27-2010 09:23 AM
Shower floor leaking...help! slloyd Plumbing 5 06-13-2009 02:34 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
