Shower Pan - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2012, 02:40 PM   #1
DIY hobbyist
Shower pan
I am going to take out an exsiting fiberglas tub and shower kit, my plan is to istall just a shower. I do not like any shower kits, so I will just design my own with concrete and tile. My question is about the shower pan. Should I buy 1 premade or should I just form 1 myself ? is it worth the extra effort ?
ggold is offline   Reply With Quote
Old 03-19-2012, 03:10 PM   #2
Rewards Points: 1,450
Probably easier with the pre-formed kit, but also a lot more expensive than using a liner to make your own....
ktkelly is offline   Reply With Quote
Old 03-19-2012, 11:30 PM   #3
Rewards Points: 918
I've never installed a pre-fab pan, so I don't know if it is easier. I've priced them (Kohler) and I can tell you that if you can install the pan for less than $1000, the site-built pan is less expensive. Of course you have to tile it for less than a grand as well.
cleveman is offline   Reply With Quote
Old 03-20-2012, 01:57 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 816
I spent quite a bit of time researching that very subject. I'm in the middle of a 2-story addition and I have two showers to put in.
Fiberglass....well...pretty obvious....ok if your doing a rental or on a tight budget...and don't want more than 10 years out of it...
Kerdi...contractors like it...quick...easy...reliable...but...expensive.
Hot mop....labor intensive....but when done right...very reliable...
I'm doing hot mop....
Basically, I can get a guy to come in and do a hot mop for about half the cost of doing Kerdi....
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 01:00 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 09:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
