-   -   Shower Pan (http://www.diychatroom.com/f7/shower-pan-128845/)
mairj40 01-04-2012 09:34 PM
Shower Pan
I have a shower floor that is tiled. I am re-doing the bathroom below it and after I abated the sheetrock on the ceiling, I found out that the upstairs shower is leaking. I am wanting to get rid of the tile shower floor and put in something more water tight. I am thinking about a poured shower floor. Can I just remove the tile and put down the waterproof membrane on the mortar that is already there since it is already sloped for the drain? Then add more concrete on top of the membrane? I guess I'm looking for suggestions.
TarheelTerp 01-05-2012 01:27 AM
Originally Posted by mairj40 (Post 812829)
I have a shower floor that is tiled...Can I just remove the tile...
Have you ever removed tile set in a mortar bed?
The odds of having anything usable remaining afterward are real slim.
Better to plan on taking that shower pan area down to the joists and starting over.
hth
ps have you fully investigated where the leak is from?
the drain fittings are far more likely to be the problem
mairj40 01-05-2012 01:47 PM
I have not yet determined where exactly the leak is coming from. I caulked around the drain and in a couple spots where the grout was missing from the tile. We have been planning on ripping the shower out and re-doing the pan, but we need to finish our downstairs bathroom first. I am just trying to stop it temporarily so I can get the sheetrock hung in the lower bathroom and get the room finished up. Then I can tear into the upstairs shower once we have a useable shower downstairs. I haven't checked to see if the leak is stopped yet. I will check tonight after work.
Bud Cline 01-05-2012 01:51 PM
Nope!
TarheelTerp 01-05-2012 01:56 PM
Originally Posted by mairj40 (Post 813466)
I am just trying to stop it temporarily so I can get the sheetrock hung in the lower bathroom and get the room finished up. Then I can...
Oh well... the best laid plans and all that.
Real world circumstances have interrupted the plan.
As you KNOW you have a problem and you KNOW you'll prefer to change things on the 2nd floor rather substantially anyway...
I'll suggest that you deal with the upstairs before closing in the ceiling below.
hth
ben's plumbing 01-05-2012 07:18 PM
yes indeed tarheel hit the nail on the head...deal with the 2nd floor issue 1st ...and as bud said can you put membrane over existing mortor....NOPE AGAIN
