Old 11-17-2011, 08:48 PM   #1
Shower P Trap clearance
Looking to install a Saniflo drain sytem in my basement to service a vanity,lav and stall shower.
Don't wish to cut up the floor,as my roomate (wife) objects.
Need to know,will 2X6's on end with a 3/4 plywood base,then a shower base give me sufficient clearance for the trap w/o any cutting.
I'm getting about 6 1/2 inches necessary by my own eye on a 2 inch trap,not including drain flange.
Any input is greatly appeciated.
Also,is their any plumbing code on height of the shower base above the floor before a step is necessary?Or is the basic rise of a stair my guide.
spring3100 is offline   Reply With Quote
Old 01-12-2012, 10:22 AM   #2
Have you made any progress on this? I'm working on the same thing in my basement. I ahve the toilet all hooked up now it's onto the shower and was wondering what you did to raise the shower base. 2x6 on it's side, then a 3/4 plywood? Was it enough for the trap & drain? How far away was the unit from the shower?
Any info/experience you had would help me out.
gilbo125 is offline   Reply With Quote
Old 01-12-2012, 10:40 AM   #3
MarginallyQualified
No farther than the required pitch (1/4" /lf?) will allow.
The pedestal is then made high enough to accommodate.
hth
Old 01-28-2012, 05:07 PM   #4
Working on the same type of project, using neoangle shower. Does anyone have photos of their finished risers?
mrkestrel is offline   Reply With Quote
Old 01-22-2013, 09:58 AM   #5
Im working the same project. Has anyone made any progress on this topic? Any pics?
rapatner073 is offline   Reply With Quote
Old 01-22-2013, 10:42 AM   #6
on the ones i have seen installed i think they had to chip a little spot out of the concrete for the trap to sit in for the shower
Old 01-22-2013, 06:53 PM   #7
I've got photos of my project I can email, don't think I can post here, worked great!! Made a riser of 2x6 presure treated & 3/4" plywood. Also chiseled some concrete to make ample room for the P-Trap. I also extended the thru wall pipe (factory told me not to do it) so I could got place pump on opposite side of stud & block walls, after a year still no issues with flushing.
Old 01-23-2013, 10:32 AM   #8
Wound up doing Dri Core flooring,then a 2 by 6 on edge framing,then a 3/4 inch Advantech board as a final footing for the shower base.
Had about 1/2 clearance for the trap,no chipping involved.
About 6 3/4 inch rise on shower stair with finished floor in.
Bonus,able to dovetail a drain for a new utility sink into shower drain going into the Saniflo pump,with bathroom sink going into the other side of the pump,and toilet going into the front of the pump casing.
S trap in basement shower? Rlly001 Plumbing 2 01-17-2011 08:48 PM
Help fixing a leak and installing a drain trap. papageek Plumbing 0 12-01-2010 12:23 PM
Delta Jetted Shower - install problems . . . Eusibius2 Plumbing 7 11-13-2009 12:21 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
