Shower P-trap Below Sewerline - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2011, 06:25 PM   #1
Rewards Points: 87
shower p-trap below sewerline
Im installing a bathroom in the basement, and the sewerline was much higher than I anticipated.
With the shower, the p-trap is obviously going to be buried, and the bottom of the trap is actually going to be lower than the sewer line.
Will this create any problems with drainage?? There will be some fall from the p-traps outlet along the drain to the sewerline.
phantasm72 is offline   Reply With Quote
Old 01-05-2011, 08:58 PM   #2
Picky Plumber
if it's close to the sewer line it SHOULD be lower at the bottom of the trap. As long as you have fall on the pipe coming out of the sewer to the wye or combo that you connect to at the sewer line, you'll be fine.
Plumber26 is offline   Reply With Quote
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
Shower trap leaks Kiwi DIYER Plumbing 1 08-30-2008 06:58 AM
