Shower Over Toilet Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2014, 01:35 PM   #1
Rewards Points: 264
Shower over toilet drain?
We are trying to put a single stall shower in our office. Concrete floor and there is already a drain from a previous toilet. Owner of the building refuses to rip up the floor to install a new drain and trap but said if we can work with what is there we're fine. So I'm thinking on building a shower above floor level, if that makes sense.
Just a panel-wall shower (no tile) and would use a pre-made pan, maybe 36x36. No trouble building a raised platform to put it on, but thoughts on how I could run a drain & trap into the existing toilet drain? Could it work?
moneymgmt is offline   Reply With Quote
Old 09-22-2014, 02:07 PM   #2
Rewards Points: 14,312
Not going to work.
There's no trap in a toilet drain.
Sewer gas will just come up the drain.
Old 09-22-2014, 03:46 PM   #3
Rewards Points: 264
Originally Posted by joecaption View Post
Not going to work.
I understand there needs to be a trap thus why I said we could build it on a raised platform and include the trap between the shower floor and the concrete.
Old 09-22-2014, 05:00 PM   #4
Rewards Points: 2,110
Not legal bro. If the shower is so important break up the floor. OR purchase a raised shower Mustee base run the drain to a floor drain that has a trap. Also make sure you purchase a temp control pressure balanced valve and not the 2 handle piece of garbage that comes with it.
http://mustee.com/product-lines/show...lls/index.html
Old 09-22-2014, 05:02 PM   #5
DIY staff
Rewards Points: 7,174
You will be creating an S-trap if you elevate the shower and place the P-trap below the pan---unless you can T- it into a vent--your installation will not be properly vented.
Your boss should spring for a jackhammer rental ($60.) and then the drain--P-trap and pan could be done properly and simply.
Old 09-22-2014, 05:07 PM   #6
Rewards Points: 582
not good for any reason......make new plans for a proper shower install...
Shower Drain 325_man Plumbing 9 06-12-2014 06:34 AM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Toilet wont drain chazlew Plumbing 11 02-27-2011 10:08 PM
