Shower Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2012, 05:41 PM   #1
shower noise
I just had the shower replaced and now when i turn on the shower it makes a deep humming noise. It doesn't seem to be banging just the noise. The bathtub faucet doesn't make any noises.
tjsmiles is offline   Reply With Quote
Old 02-11-2012, 05:42 PM   #2
My pop up blocker is now disabled. Can you try again?
Old 02-11-2012, 05:56 PM   #3
Rewards Points: 12,812
Drop leg elbow is loose, the hole in the wall where the spout comes through the wall was made to tight, the riser pipe is rubbing againt something.
A simple test would be to remove and replace the shower head with a cheap one and see if it still does it.
tjsmiles (02-15-2012)
Old 02-11-2012, 06:13 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
You could just grab on to the gooseneck for shower head and try pushing/pulling on it to test that.
Try removing the shower head to see if it gets quiter,did you remove the restrictor from the shower head before installing it?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 02:17 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Flush toilet, hear shower drain noise joedadog Plumbing 1 04-01-2006 01:52 AM
