Shower Moisture Barrier - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2013, 09:15 PM   #1
shower moisture barrier
hi guys,
I was thinking on adding a shower stall. I just had a quick question. I was planning on adding either 6 mil poly to the studs or roofing felt, then cement board 1/2" then kerdi membrane on top of that. Now, would that be considered a double moisture barrier? I know that is a no no since it can trap moisture.
mikem201 is offline   Reply With Quote
Old 04-17-2013, 03:49 AM   #2
Rewards Points: 4,796
Yes, there is no need to use plastic along with the Kerdi. It could even be bad, although only in the case of something being really wrong. How could moisture get in there?
jeffnc is offline   Reply With Quote
Old 04-17-2013, 07:56 AM   #3
So, that would be considered a double vapor/moisture barrier?
Old 04-17-2013, 10:13 AM   #4
Well, of course a sheet of plastic and a sheet of Kerdi with space in between would be considered a double moisture barrier. The question is if it would cause any harm. It certainly isn't necessary.
Old 04-17-2013, 11:56 PM   #5
Registered User
Rewards Points: 526
Not a problem. If 2 v.b. with insulation/framing between, then a problem.
Gary
moisture barrier question jackwashere Roofing/Siding 6 10-17-2012 08:15 AM
What type of moisture barrier is needed for solid hardwood naildown flooring? htabbas Flooring 10 11-30-2011 07:51 AM
Basement floor finishing: Moisture Barrier? junior.carls Flooring 2 08-31-2011 10:51 PM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Moisture Barrier and Adhesive Removal joe_cole5000 Flooring 5 01-31-2010 03:06 PM
