Shower Mixing Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-23-2013, 02:14 PM   #1
Shower mixing valve
Is there a stop in the mixing valve the handle is now in a different position and after Turing on the water it stops(the water) halfway, then comes on again
Rtraino2 is offline   Reply With Quote
Old 04-23-2013, 03:10 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
Each valve manufacturer has different way to control the on/off.
You will need to pull the handle to see if the stop broke or wore off and how your particular valve works.
If you need more guidance- try to add a picture of your valve and we can help more.
Moving/Installing new mixing valve... issues with framing rodney23 Plumbing 6 12-12-2010 03:32 PM
Can't Identify Shower and Tub rough in valve stamped SHWR 7196 and TUB P-P USA help4diy Plumbing 1 11-21-2010 09:06 AM
Is this a mixing valve problem? imola ghost Plumbing 2 05-31-2010 10:52 AM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
I thought I put it back together properly: leaky shower valve (Matco-Norca) shuuy Plumbing 1 06-18-2009 10:44 AM
