Shower Liner On Basement Concrete. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2012, 10:00 AM   #1
Siubeer's Avatar
Shower liner on basement concrete.
Hi,
I'm a bit confused about which order to build my basement shower pan.
It's going in the basement.
I've poured the curb already.
Question is. Next. Do I lay the rubber liner 1st then put the sloping mortar in? Or do I put the mortar directly on the cement floor then put the liner on top of it?
Please advise,
Thanks!
Henry
Shower liner on basement concrete.-image-3645105277.jpg   Shower liner on basement concrete.-image-2841164947.jpg
Siubeer is offline   Reply With Quote
Old 06-21-2012, 06:20 AM   #2
DIY staff
Rewards Points: 7,174
How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
This should be a start---ask questions after reading it---
Old 06-21-2012, 10:59 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Should have done some research BEFORE you poured your curb. The liner gets cast inside the curb.
There are other ways to do it but you will have to change liners and methods now.
Oh-Mike can point you to a How-To somewhere, he's good at that.
If you have any questions you can't get answered here, or you need serious personal assistance, email me. Be glad to help.
Old 06-28-2012, 12:10 AM   #4
Siubeer's Avatar
Oh, i got it figured. The liner is going ontop of the cement curb and preslope. Then i'm putting lathing ontop of the curb and mortar everywhere. Then tile.
The Following User Says Thank You to Siubeer For This Useful Post:
oh'mike (06-28-2012)
Old 06-28-2012, 09:30 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well okay if you want to continue to do things the hard way, go right ahead.
Old 06-30-2012, 12:47 PM   #6
www.No-Curb.com
JohnFRWhipple's Avatar
Good on you for doing a pre-slope under your liner.
How old is that slab? Is it crack free? If the slab is old, cured and in good condition you can use a product from Mapei called Mapecem Pre-Mix fast Setting Screed Mortar to prepare your pre-slope. It can go from 1/4" to 4" in thickness and need a slurry coat made from the same Pre-Mix and Planicrete AC. This layer will set up in under four hours and you can cover with the liner the next day (14 hours later).
Noble company has a preslope that installs in under five minutes and you might consider this if you don't want to make one from concrete.
Make sure you flood test your shower. It's the only way you will know it functions properly.
After you pull the plug make sure that all the water drains. Protect your weep holes from plugging and set in your tile prep layer. Over a liner it will need to be from 1 3/8" to 2" thick, depending on what mortar you select.
You can at this stage use a NobleFlex Flashing tool (1 1/2" ) version and go with a bonded membrane called Noble Seal TS, or Dal Seal TS, or Noble Deck, or Noble CIS. This will skip one of the mortar layers and speed things up.
Good luck!
JW
"When it's Perfect. It's good Enough." - John Whipple
JohnFRWhipple is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Shower pan liner help mikkik Plumbing 26 12-15-2010 09:41 PM
How do you install a walk-in shower in a basement with floating walls? ronquillor Tiling, ceramics, marble 1 02-20-2010 05:57 PM
Concrete Basement Beam jrepp44 Building & Construction 1 01-06-2010 02:39 PM
How to seal a shower pan liner against a concrete foundation wall? mgray87 Kitchen & Bath Remodeling 3 08-13-2009 12:08 PM
