Shower Leaking Into Closet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2012, 12:50 AM   #1
Shower leaking into closet
My master shower is leaking into the closet. I cut a hole in the closet behind the shower knob, turned on the shower and saw water dripping from above. So, I cut a hole a few feet above that, behind the faucet, only to find that the faucet is attached to a horizontal stud, thus blocking my view of where the leak is actually happening. The shower stall itself is one big plastic unit. I removed the caulking around the faucet and removed the face, but the hole is barely big enough for the faucet to come through, so it doesn't allow me any room to work in there. Any suggestions??? Thank you!
brianplaysmusic is offline   Reply With Quote
Old 01-20-2012, 02:09 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Too back it's not the coat closet, huh?
So nothing gets wet?
You'll have to keep removing sheetrock until you can get to whatever is leaking, and probably, carefully, get that "horizontal stud" separated from the faucet.
You'll either need a sawsall or a catspaw most likely for that.
You need to do some drywall repair anyway, what's a little more?
Try to cut the sheetrock at center of the adjacent studs, straight and square, to make that repair a little easier on yourself once you fix the leak.
One more thing: Make sure the leak isn't coming from where the shower head screws into the fitting, and it's not just simply a matter of a couple of turns.
Of course if this was the case, it would only leak when you turned the shower on.
titanoman is offline   Reply With Quote
Old 01-20-2012, 06:53 AM   #3
DIY staff
Rewards Points: 7,174
Remove the shower arm---dope (tfe paste) and teflon tape--then re install
That might be all you need to do---
Old 01-20-2012, 09:00 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,822
First rule of any repair....try the easy simple things first.
Second rule of any repair.....if you have to cut into drywall....make the hole big....a big hole is easier to repair than several little ones.
I would do what Mike suggests.....it's not uncommon for the head to be replaced and in the process the arm gets loosened...breaks the teflon tape seal....and then leaks.
Old 01-20-2012, 09:12 AM   #5
DIY staff
I've seen that all to often--that's why the DOPE and tape---it's very easy to knock the tape loose when slipping that chrome tube into the wall----
Most common leak point in a shower wall in my world----
Tags
access , leaking , shower , stud
Leaking shower in 2 story townhouse. Toggleme Plumbing 6 11-05-2011 04:59 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Leaking shower in mobile home disna Introductions 5 12-12-2009 07:42 PM
Shower floor leaking...help! slloyd Plumbing 5 06-13-2009 01:34 PM
Another leaking shower post sn0wl0ver Plumbing 2 08-27-2008 05:37 PM
