Shower Leaking Hot Water, Replaced O Ring, Still Leaking, Need Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2013, 04:48 PM   #16
Plumber
Originally Posted by oh'mike View Post
After you remove the stem from the valve body---look inside the open hole where the stem goes-----all the way in the back ,you will see the opening that your rubber washer will touch when the stem is installed---
That is the 'seat'---they get pitted and coroded after years of use.
You can remove and replace that 'seat' --most use a long Allen wrench and simply unscrew----
If you have a plumbing supply house near by, you might get better advice and the right parts.---The Depot may have a few valve seats---but a supply house will be a better bet---Mike----
PS--rebuild the hot and cold while you are at it----and ask for a roll of 'valve stem packing' while you are at the store.
These two pics should show you what Mike is describing.
DidIDoThat is offline   Reply With Quote
The Following User Says Thank You to DidIDoThat For This Useful Post:
oh'mike (09-09-2013)
Tags
leaking , rubber , shower , washer
Replaced shower faucet and now water isn't warm...Help! Girl-DIY Plumbing 4 06-05-2011 03:08 PM
Draining water out of shower pipes docmattman Plumbing 9 05-23-2011 07:43 PM
Hot/Cold water problem in shower 8thebroker8 Plumbing 8 06-30-2010 06:12 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 01:59 PM
