Shower Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2011, 12:34 PM   #1
shower leak
I have a Kohler Single Control Shower Valve K-15102. I have replaced the GP71969 Valve Mixer Kit, and the GP500520 PBU service part kit to stop the shower head from dripping. Now water leaks badly from the 4 screws that hold the Valve Mixer and assembly to the body. I have tried every possible combination to the assembly. Kohler=.
flustered diyer is offline   Reply With Quote
Old 01-30-2011, 12:54 PM   #2
Assuming the parts are correct my first guess would be you are missing an O-ring or gasket of some sort between the parts. Or could be the O-ring is not seated in the part correctly.
Mike
Mikelite80 is offline   Reply With Quote
Old 01-30-2011, 01:02 PM   #3
that was my first impression. All new o-rings and have tried various positions of rings, no luck. Planning a call to Kohler in morning.
Old 01-30-2011, 01:13 PM   #4
Here is the exploded diagram. Looks like there should be 2 O-rings after the PBU. Looks like 1 would be included with the the valve repair kit, but the other (42043) should be reused with the body. Maybe it fell out when taking it apart and thought it was from something else. I know I've done that before. Hope this link works....
http://www.kohlerserviceparts.kohler...366a4d408f3d97
shower leak..hot water tank leak...HELP!!! Drie Plumbing 6 06-30-2010 02:12 PM
Mold growth in basement under shower. Need suggestions to fix leak and clean up mold vseven Plumbing 6 12-10-2009 02:33 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 05:58 AM
Shower Leak mop Tiling, ceramics, marble 3 05-25-2009 09:46 PM
