-   -   Shower Leak (http://www.diychatroom.com/f7/shower-leak-18714/)
mcorn 03-19-2008 09:41 AM
Shower Leak
:help: In the middle of a bath remodel. Had everything down to the studs. Had contractor com in and complete plumbing and electrical. All the walls are back up and I am ready to tile I noticed water on the floor. Water is leaking from the bottom of the drywall on the back of the shower. On the other side of this drywall is the shower plumbing. This wall has been up for a month and just started showing signs of a leak. What would cause a leak when we are not using any water in the bathroom at all. The toilet is not in yet and the shower has not been tiled yet. Could it be that the pressure built up in the shower pipe and that is why it is just now leaking? Help
Mike Swearingen 03-19-2008 09:44 AM
The shower faucet body must be leaking at connections. Have your contractor come back in and correct the leak and all damages, including the drywall, at his expense.
Good Luck!
Mike
mcorn 03-19-2008 10:07 AM
Thanks Mike
Double A 03-19-2008 11:44 AM
Did you put a fastener in one of the pipes by mistake?
bubbalouiex 03-21-2008 01:38 PM
just curious, is there a problem with putting a fastener in the line?
