Old 08-03-2010, 03:40 PM   #1
Shower into a bathtub
I have gutted my master bath that was a center shower drain but want to convert it into a bathtub, is this possible without digging up the drain and replacing it? If it is can someone give advice on how to go about doing this.
Thank you in advice,
Adrienne
Adrienne331 is offline   Reply With Quote
Old 08-03-2010, 08:37 PM   #2
Super Moderator
You are going to need a new drain---open the floor!--Mike--
Old 08-03-2010, 08:44 PM   #3
Here is where I am at on this journey Jim's downstairs bathroom project although I have made some progress since the latest pictures posted. Are you talking about an alcove tub, drop in or freestanding? The alternative to moving your shower drain would be build your tub alcove/frame around the old shower drain, space providing. Also tubs typically use a 1 1/2" drain whereas showers typically use a 2" so you are probably going to have to do something whth that old shower drain. Another one of those "pictures would help" scenarios I think.
Jim F is offline   Reply With Quote
Old 08-03-2010, 08:45 PM   #4
Uh, yeah what Mike said.
Old 08-03-2010, 10:13 PM   #5
I will be putting in a slide in bathtub. So since my drain is in the center I would have to relocate everything to accommodate the bathtub correct?
Thanks all
Old 08-05-2010, 07:17 PM   #6
Yes and don't forget you are going from a 2 inch diameter down to a 1 1/2 inch diameter drain but that would become evident once you got the tub in place.
Tags
drain, shower, tub
Converting Bathtub to Shower enkay18 Kitchen & Bath Remodeling 2 07-14-2010 03:05 PM
Convert a shower into a bathtub romacarl Plumbing 3 03-05-2010 03:32 AM
Bathtub faucet runs when shower is on aggyanna Plumbing 2 12-21-2009 10:21 AM
need to convert a bathtub into a shower q5485 Plumbing 9 11-30-2008 10:39 PM
convert bathtub to shower argos Plumbing 10 02-20-2008 12:53 AM
