Shower Hot Water Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2008, 08:08 PM   #1
Question
shower hot water problem
Hi,
We had a new bathroom built in our second story addition last summer and have been having some difficulties with the hot water for the shower/tub. It is a Delta single handle with the heat adjustment on the handle(hope this makes sense). Sometimes it just doesn't get very hot. However, this does not happen in our other shower or at any of the sinks. It seems to happen randomly, but can not be tied to the dishwasher running or doing the laundry. What else could it be?
Thanks in advance!
ajoantmug is offline   Reply With Quote
Old 01-15-2008, 08:18 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
Sometimes does not get hot? I would check the sink in the bathroom, if that water is nice and hot, then it is the adjustment inside the valve.
NO NEED TO TURN WATER OFF
1 PLACE A WET WASHCLOTH OVER THE DRAIN SO NOTHING GOES DOWN THE DRAIN!!
2 pop off the cover on the temp handle
3 look in the center, there should be a philip screw, remove this
4 pull off the temp knob
5 look inside the center, there should be a gear inside a gear, rotate the center gear to allow the temp knob to turn all the way open
6 replace parts
7 test
8 if it is colder, then go back into the gears, you turned them the wrong way, simply turn the other way
USP45 is offline   Reply With Quote
Old 01-16-2008, 02:20 PM   #3
How large is the hot water tank?
(40, 50, 80...) gallons
redline is offline   Reply With Quote
Old 01-17-2008, 01:08 PM   #4
Thanks for your replies. I will try what you suggested about adjusting the gears when the problem arises again. It does happen somewhat frequently, and yes randomly. The water heater volume reads 71 gallons the first hour?
thanks
Old 01-20-2008, 11:44 AM   #5
Thanks USP45, I adjusted the scald guard and everything is perfect.
Old 01-21-2008, 04:39 AM   #6
Thanks for the information USP45. They are very useful. I'm glade that I've found this forum. If I will have a problem I will ask you for sure.
great is offline   Reply With Quote
Water dripping in the shower??? Sellncars Plumbing 4 12-05-2009 08:07 PM
hot water recirculating/sediment confusing problem rcatty Plumbing 1 01-06-2008 03:51 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
water pressure problem rgmetro Plumbing 6 04-09-2007 03:57 PM
Shower Pressure Problem rob1970 Plumbing 18 03-10-2007 10:41 AM
