Shower Heads - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-10-2013, 10:23 AM   #1
Rewards Points: 83
Shower heads
Sent my wife out to buy a shower head and she came home with a 5" delta head.. Don't like it no pressure . I went to my second bathroom and removed a small head and replaced the big head, the thing works great, tons of pressure. Is there anyway to increase pressure in the 5" head?
Ralph Coolong is offline   Reply With Quote
Old 07-10-2013, 10:32 AM   #2
Rewards Points: 18
"Flow Restrictor" in shower head.
Something similar to the white plastic piece. Some are easy to remove while others not so much. Should be right near the inlet.
Jtom is offline   Reply With Quote
The Following User Says Thank You to Jtom For This Useful Post:
Ralph Coolong (07-10-2013)
Old 07-10-2013, 10:34 AM   #3
Rewards Points: 83
Thanks, I will give it a go.
Old 07-10-2013, 11:45 AM   #4
MarginallyQualified
Rewards Points: 2,464
I remain a BIG fan of the 'jet' type spray heads.
Especially the ones with the "navy shower" on-off button.
About $5 at most stores... plenty of pressure. No waste.
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 09:45 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
installing multiple shower heads jimmy21 Plumbing 5 07-02-2008 09:46 AM
