Hello,
After doing some searching and turning up nothing I would like to ask here. Maybe someone has used this... if it exists.
My house is mostly concrete wall & ceiling. In my bathroom we are going to tear out the old corner shower and put in a new one. Right now the plumbing is going through a framed wall which we will be tearing out and replacing with Glass Block. I will frame a little bit along the concrete wall, enough for hot and cold water to go up to a dropped down ceiling, which is framed down from the concrete ceiling.
I want to send the water to the ceiling where the spout will be (rather then tear up brick walls, both of which are common walls). I am thinking of using a showerhead that has a hose. The only ones I can find have the mount for the shower head built onto the spot you connect to the water spout.
My questions:
Are there any shower heads that have a mount independently of the spout?
What are your experiences with shower heads that are meant to mount on the ceiling?
My questions:
