Shower Head Standard - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2008, 10:05 PM   #1
Shower head standard
So We purchased this beautiful rain shower head and faucet set from kohler...my husband is demanding we HAVE to mount it to the exact measurements it says in the direction booklet. If we do so the shower head will rub the top of my head and he would have to duck to get under it..he is still saying it ABSOLUTLY must be mounted this way. Does it...im explaining it is probably a standard, he says not its to code..i explain to him that a manufactures direction booklete does NOTE know the codes of manchester township in PA.
Can we mount this shower head higher if we need to in order to fit under it or will it not work properly?
Demochick is offline   Reply With Quote
Old 02-28-2008, 10:46 PM   #2
Just install it at a comfortable height. Yes we have codes on heights , but unless you are calling an inspector for a shower head replacement, relax. I've been plumbing for 20+ years and never had an inspector even look at the height of a shower head in a home.
It will work at whatever height you put it , unless you have that special water that is afraid of heights
Pipes is offline   Reply With Quote
Old 02-28-2008, 11:30 PM   #3
ACE Hardware, for one, sells a 2-point pivoting arm in chrome finish that mates up the existing arm - no matter what height you settle upon - and permits you to raise or lower the actual shower head to suit your comfort level. That way, both of you get what you want.
End Grain is offline   Reply With Quote
Old 02-29-2008, 07:11 AM   #4
[, unless you have that special water that is afraid of heights [/quote]
I guess thats what he thoght.... thanks he did finally do it my way
Old 02-29-2008, 09:23 AM   #5
Does this mount on the ceiling or the wall?
redline is offline   Reply With Quote
Old 02-29-2008, 09:25 AM   #6
Originally Posted by Demochick View Post
... he did finally do it my way
How dare him question your logic.
You have him trained well
Old 02-29-2008, 03:00 PM   #7
It mounts on the wall...trained well...no he just gets tired of me yellin..lol j/k he actually agrees once he actually listens to the words coming out of my mouth.
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
Shower head not working, having trouble with replacing the tub spout keyser soze Plumbing 26 06-12-2007 08:39 PM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 10:05 AM
Stuck shower head stealthxcat Plumbing 1 05-08-2007 10:19 PM
Shower Head Draining pinfordend Plumbing 2 05-04-2006 07:30 AM
