Shower Head Piping - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2013, 09:30 PM   #1
Shower head piping
Hi,
I'm working on installing my shower head piping and there's an interesting issue. I'd like to put a recessed shower "box" right where the pipe for the shower head would run directly up from the valve. So I figured I had to create some 90degree bends. Attached is what I did so far and I included pics with a measuring tape.
So my question is, is there a rule of thumb for distance of pipe before installing a 90degree elbow? I know the goal is to minimize the number of bends. However, in this case, I don't have many options.
Any advice would be greatly appreciated. Thanks
Shower head piping-imag1240.jpg   Shower head piping-imag1244.jpg   Shower head piping-imag1245.jpg   Shower head piping-imag1246.jpg   Shower head piping-imag1247.jpg
netdude is offline   Reply With Quote
Old 04-10-2013, 09:42 PM   #2
Rewards Points: 12,868
No idea why you all those 90's. Should have been straight up and a drop leg elbow.
Old 04-10-2013, 09:50 PM   #3
I'd like to install a recessed shower "box" right in front. The box blocks the pipe so I had to go around the box, thus the 90degree fittings.
Old 04-10-2013, 10:01 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
I would have gone with 45's myself, of course it would reduce how much of an area you can recess though. Also, make sure you put it nice and tight, I hate when shower heads and taps feel all loose, and once the shower is in place there is no way to go back and fix it. My shower is like that, was done by a pro too... wish I had noticed before he put the shower in.
Old 04-10-2013, 10:30 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 984
Thats gonna be a noise maker should have used 45s like RED said.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-10-2013, 10:31 PM   #6
funfool's Avatar
Rewards Points: 534
I call them Nicho's here in Albuquerque. I was just looking at all that free space behind the shower wall, was wondering if maybe you were going to build a entrance to a cave behind a waterfall
There is no problem with running the elbows up to the shower head, sometimes we run the piping up and over into the ceiling and have it come down from the ceiling and not out from the wall.
I like to use the new prefabbed plastic nicho boxes when I can, just saves hours of work, considered building from scratch.
When I have that much free room to work with, I prefer to build my own nicho with my dimensions, tell the plumber to just work around it.
The store bought are great but typically for a 2x4 or 2x6 wall, while a 8" nicho is really nice.
funfool is offline   Reply With Quote
Old 04-10-2013, 11:33 PM   #7
Awesome... Thanks.
My nicho actually is plastic. It's pre-fabbed and you just tile over it. It's called redi-tile or something.
As for the 90's, yeah, there's a lot of them. I was thinking 45's, but had a bunch of 90's in my bag and figured I probably wouldn't notice the water pressure loss using 90's.
Any last thoughts before I solder this bad boy on? Thanks!
Old 04-11-2013, 01:19 AM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
I have a few 90s in my shower and if there is noise I can't hear it, come to think of it I don't hear much of anything.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
framer52 (04-11-2013)
Old 04-11-2013, 06:51 PM   #9
Rewards Points: 1,706
If your building with tile make real sure you water proof your box before you tile....
http://www.laticrete.com/contractors...rproofing.aspx
Old 04-11-2013, 07:55 PM   #10
Thanks. I'll be building using a pre-fabricated box from redi-tile. It's plastic. I plan to install it, then install hardibacker, then tape up and use redguard around the edges to ensure it's fully sealed.
Shower head dilemma segal Plumbing 2 01-24-2013 12:34 AM
LOW Pressure on Shower - Need head suggestions! LordX Plumbing 5 06-02-2012 02:08 AM
Threaded shower head connection too close to ceiling anygren Plumbing 6 10-11-2010 02:41 PM
High pressure Shower Head Carloscda Plumbing 9 06-18-2010 01:50 AM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 06:49 PM
