Old 11-04-2009, 12:04 PM   #1
Default Shower Head Pipe
How do you install a shower head pipe so that the 45 degree downward portion is in the correct position?
Lees73 is offline   Reply With Quote
Old 11-04-2009, 08:06 PM   #2
Home Remodeler
Put extra teflon tape on the threads so it will tighten in the correct spot.
mikey48 is offline   Reply With Quote
More On This Topic
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
You should select furniture making plans primarily on your skill level. Plans that are too complex or which require special equipment may only serve to frustrate you. Fortunately, furniture making plans and furniture "how-to" articles are widely... Read More »
Hi! I am Angela on behalf of expertvillage.com, and right now I am going to be taking about posture and the pains that can be induced from poor ergonomics and posture. Ergonomics is how your back is positioned and how your chair is structured. If it is... Read More »
Pipe offset in shower drain RWThrun Plumbing 4 07-30-2009 08:03 AM
Fixing leaking shower head...turns out pipe coming out of wall is the source plumbingboy9317 Plumbing 5 05-25-2009 03:41 PM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 03:02 PM
Ceiling Mounted Shower Head bounc4 Plumbing 1 01-16-2009 07:30 PM
Shower head compatibility (complete novice) jnod Plumbing 1 10-26-2005 10:32 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
