Shower Head Not Working, Having Trouble With Replacing The Tub Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2007, 09:47 AM   #16
Sorry to disagree with Ron but I have sweat on male iron pipe adapters to the copper stub for screwed on tub spouts. Many of these were before the slip-on got popular.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-11-2007, 11:12 AM   #17
Rewards Points: 530
You sweated galvinized pipe to copper??? Can't think of the name for it, but I thought mixing mat's like that without proper adaptors would cause them to corrode.
Old 06-11-2007, 11:52 AM   #18
Bowman, No, it is a sweat to threaded adapter made of copper. Sweat the adapter on the end of 1/2" copper stub from the wall and it made the end of the stub threaded for the tub spout to screw on to. The name "male iron pipe adapter" is just the transition that is made with the fitting. This seperates it from a sweat to garden hose thread which is different. Male iron pipe is a thread type, not the material it is made of. Sorry for the confusion.
Old 06-11-2007, 12:06 PM   #19
Rewards Points: 530
My bad, Maj. Adapters didn't register in this old brain.
Old 06-11-2007, 12:42 PM   #20
No problem. This old brain here sometimes forgets that not everyone in Forum sites knows the terminology. Now more people do.
Old 06-11-2007, 05:55 PM   #21
Journeyman Plumber
Ron The Plumber's Avatar
If you can't unscrew it, you can still cut it off, even if you cut the face off and if you do cut though the copper pipe, cut the spout off midpoint, this way you will be cutting off the existing MIP adapter you can still fix it by sweating on a coupling and small piece of pipe with new copper Male Iron Pipe Adapter allowing you to use a new screw on type of spout.
I didn't see a problem fixing this, fast and simple, but if you not so sure then do call in a plumber.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-11-2007, 06:01 PM   #22
Journeyman Plumber
So true, I was only taking a stab at it, I have seen where plumbers will turn the slip on spouts to the side to tighten up the set screws, then turn them down into position, this causing the threaded part of the spout at the same time, then when one goes to locate the setscrew is has been repositioned inside the housing, this making one believe it's not a slip on type, without being there, one can only assume what it is that is being dealt with.
Old 06-11-2007, 09:31 PM   #23
Rewards Points: 530
Heheh, I know what adapters are. I meant it was kind of like I didn't see the word. I have used them before myself. when I seen 'sweat on male iron pipe' my mind skipped the word adapters. Kind of blwe my thought procees for a sec. That does not take much lately.
Old 06-12-2007, 06:39 AM   #24
Since I don't have a plumbers torch I think I'll just go ahead and call a pro. :hangs head in shame: As mentioned, if they break it, they'll have to fix it.
If they say something about not being responsible for damage, I'll just say that I won't be responsible for paying either.
I should be able to find someone to do this for a reasonable price, I know it will be more than I want to pay (nothing) but it will be worth it to know it's right. I don't want to have a plumber show up to fix a spout that's hacksawed, torched, and beaten. Worse yet, then he'd probably just look at it and it would fall off. haha That would be my luck.
Thanks a lot for all of your help and guidance gentlemen. If I can't find anyone to fix it on short notice I might go ahead and mess around with it a little more just to see what I can do.
"Good judgment comes from experience. Experience comes from bad judgment."
keyser soze is offline   Reply With Quote
Old 06-12-2007, 08:50 AM   #25
Let us know what the end of the story...I meant what happen...
I won't be surprise, after the pro come, it ends up be a 10 minutes job for them... much less serious than you thought... and they charge you for $60 bucks....
KUIPORNG is offline   Reply With Quote
Old 06-12-2007, 10:17 AM   #26
Keyser. If you still want to play with it and not do physical damage, you could try just giving it a twist and pull motion. If it is a slip-on, it may slide right off. Don't know why there isn't a set screw but stranger things have happened.
Old 06-12-2007, 07:39 PM   #27
Originally Posted by boman47k View Post
Glad to see a plumber reply. I am not a plumber.
I am.
Ishmael is offline   Reply With Quote
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 09:05 AM
Stuck shower head stealthxcat Plumbing 1 05-08-2007 09:19 PM
Replacing damaged shower wall tiles kevind Flooring 4 11-20-2006 12:18 PM
Replacing damaged shower wall tiles kevind Remodeling 3 11-15-2006 10:36 PM
Shower Head Draining pinfordend Plumbing 2 05-04-2006 06:30 AM
