Shower Head Leakes, But At Least It's Straight!?!?! - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2009, 10:06 AM   #1
Shower head leakes, but at least it's straight!?!?!
Hey, I am remodeling my bathroom and have a question on sealing the threads on the shower head arm.
What I have coming up from the shower control valve is PEX, up to a Shark Bite fitting/female adapter, and into this I have screwed in the shower head arm.
Now, I used standard white Teflon tape and wrapped it around 3 turns. Once I screwed it in, I got it fairly tight...could have been a bit tighter, but the concern was that I would have turned it past being straight, and it would no longer look straight--it would be cockeyed. So I got it fairly tight but not quite as tight as I would think it needs to be.
I turned on the water and sure enough, had a very very slow drip out of that fitting.
So what do I do:
Wrap the tape 4-5 times?
Use yellow or pink tape, because it's thicker?
Use dope instead of tape?
Continue to tighten the shower head arm an additional 15-20 degrees clockwise or so to get it really tight, causing the arm to not be straight?
Thanks and be kind as I am a first time plumber & remodeler
rebaths is offline   Reply With Quote
Old 02-01-2009, 10:16 AM   #2
biggles's Avatar
try it dry with no tape to see those CW turns(count them) to see where it ends up an it is straight.2,3,4 wraps just make it tighter faster so judge that ..... and anticipate that final turn.the big non-critical thing there is it isn't a standing pressure like the water at the selector hot/cold.it is a running water when your in the shower,and the only restriction is the water coming out the shower head in a spray.
Old 02-01-2009, 11:52 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,618
So what do I do:
Ayuh,.... Go 1 more full turn.......
Bondo is online now   Reply With Quote
Old 02-02-2009, 08:32 AM   #4
RippySkippy's Avatar
-- sure it wouldn't hurt
-- no the white is fine.
-- use dope WITH tape.
Continue to tighten the shower head arm...
-- no it will look really bad.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 02-02-2009, 05:22 PM   #5
rippy is right use dope and tape, first wrap the tape, make sure your wrapping in the right direction, so the end of the tape should face the opposite direction of the direction of threading, so you twist the shower arm to the right, the end of the tape should face to the left. Thats to prvent the end of the tape getting caught on the female threads. . then dope it.
zosoplumber is offline   Reply With Quote
Old 02-02-2009, 07:19 PM   #6
plumbing contractor
PLUMBINGITALL's Avatar
Wrap the threads 6 times and you should have a good seal.
PLUMBINGITALL is offline   Reply With Quote
Old 02-02-2009, 07:22 PM   #7
Although I could have the picture wrong, someone is going to mention not to bury shark bites in the wall, hot topic but wanted to throw that out there for you.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 02-02-2009, 08:40 PM   #8
There is no problem with shark bites behind a wall. That passes code. At least where i live... those things are tested up to like 300 psi or something crazy like that... my concern is that you are running pex to the shower... are you using 3/4"?... because ive heard of people having volume issues when running 1/2" PEX to a shower head.
scotty123 is offline   Reply With Quote
Old 02-02-2009, 09:32 PM   #9
Man of many hats
wrangler's Avatar
Rewards Points: 354
As said before, tape ( I like to do 5 times in a clockwise direction as you look into the hole) and dope provide your best seal, but as for tight, it may actually not be as tight as it can go. Take a pair of pliers(I like to use my 9" channel locks) and stick one of the handles into the neck, then continue to turn it till it is not only tight, but pointing down in the right direction. You will find that you can often go 3/4 of a turn further this way than you can just by hand.
HTH,
Brett
Man of many hats
wrangler is offline   Reply With Quote
Old 02-03-2009, 10:11 AM   #10
Rewards Points: 1,536
I would go with five complete wraps using white tape which should do it. This way if the shower arm tightens up with the end cockeyed (say 8 o'clock) there is enough give to to get it all the way around back to the proper 6 o'clock position without tearing apart the elbow inside the wall.
Looking at the shower arm pipe end, press the Teflon tape on top with the tape end going to the left. When you finish wrapping, the tape will then go over the top with the free end to the right. As you point the shower arm into the wall the exposed tape end should be seen going over the top to the left or going under to the right.
Old 02-03-2009, 06:28 PM   #11
The actual shower valve is fed by 1/2" supply so sending 3/4 pipe up to the shower head is pointless.
Shower Head Breaking Off mbarnes Plumbing 3 01-11-2009 06:38 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 11:23 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 05:49 PM
Stuck shower head stealthxcat Plumbing 1 05-08-2007 09:19 PM
