Shower Head Install Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2013, 12:25 PM   #1
Shower head install question
Hi. I just purchased a Waterpik shower wand/head unit and installed it per the instructions and have a question.
Where the hose comes out of the wand mount bracket, which is also where the vacuum breaker is located in the hose, when I shut off the water the water leaks out of this area. Is this the way this vacuum breaker is designed to operate? It is not leaking out of the threads so I do not believe pipe tape is the issue.
Thank you.
Chris
ysrchris is offline   Reply With Quote
Old 05-12-2013, 12:37 PM   #2
Rewards Points: 2,516
You sure its not a water saver shutoff/valve? Either way it is designed to drip from the show head so that you do not get scalded when turning the water back on.
hammerlane is offline   Reply With Quote
Old 05-14-2013, 07:58 AM   #3
RE: Shower head install question
Did you try removing the entire mounting from the shower head and retightening it? You could also use some tape over the existing threads and see if that stops the problem. If not, I'd just exchange the entire unit for a new one - it may be a factory defect.
Retroloco-LJ
http://fhfurr.com
Retroloco-LJ is offline   Reply With Quote
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Shower head replacement zachg Plumbing 10 01-24-2010 08:21 PM
Problamatic shower head install. speedster1 Plumbing 1 01-04-2010 03:06 AM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 12:59 PM
Delta Jetted Shower - install problems . . . Eusibius2 Plumbing 7 11-12-2009 11:21 PM
