Shower Head Height Above Bathtub Question? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-20-2011, 07:12 PM   #1
wraiththe's Avatar
Rewards Points: 91
Shower head height above bathtub question?
HI,
I am rebuilding a bathtub/shower. We replaced the tub with a better soaker tub that is 19" high. The floor of the tub is no more than 2" above the floor. We are both about 5'8 and are wondering how high the shower head should be? The plumber came in and raised the head and pipes about 1.5" and now it is @83" above the floor. This seems too high. (They head has always seemed way to high.)
We plan on either going 63" above the tub with tile (6x10+3) or 73". since the tub is 19" high that means if we go with 63" of tile, the head will be just a little over an inch above the tile. If we add a 3" ribon of small stone that would put the head in the bullnose... yuch.
We also realize that later someone taller than us might move in. What height should we ask the plumber to move the head to?
wraiththe is offline   Reply With Quote
Old 11-20-2011, 07:36 PM   #2
I'm 6'1"...
....and the most annoying thing is when the shower head (either in a home or hotel) is set too low!
I think you should set it for the height that's comfortable for you both, when it's too high you lose pressure and the shower experience really changes. Keep in mind that the hole in the wall where the pipe comes out isn't key here, it's the actual end of the shower head, which you (and subsequent owners) have some control over b/c of the length of the goose neck and thickness/length of the actual shower head.
My shower head is about 6 inches or so from the top of my head, FWIW, and it works fine.
Westy is offline   Reply With Quote
Old 11-20-2011, 07:48 PM   #3
All right, let's settle this "shower head height" problem once and for all!
First of all, all plumbers from the 60's and 70's were short people. That is why these shower heads are at my nose level (I'm tall!)
Lately plumbers have been taller and have been installing them higher...
Anyway how about a compromise between us tall people and shorter people... That is in the wall, install a "T" at the lower height you prefer, then continue the pipe up a little, then install a 90 degree elbow, then plug that.
Then you could have the shower head lower for now, then just move it up and move the plug down if you decide to sell the house in the future. Point out to potential buyers that there is an adjustable height shower head!
Billy_Bob is offline   Reply With Quote
The Following User Says Thank You to Billy_Bob For This Useful Post:
wraiththe (12-01-2011)
Old 11-20-2011, 08:26 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 348
Put it high and install a shower arm to meet your height- simple. Don't over think this.
Better yet, put the outlet in the ceiling and use a rain head.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 11-20-2011, 09:01 PM   #5
I always install at 78" above tub floor, unless the homeowner specifies something different.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
Old 11-20-2011, 09:07 PM   #6
If it is too high maybe you can jack the house up about six inches
broox is offline   Reply With Quote
The Following User Says Thank You to broox For This Useful Post:
VIPlumber (11-20-2011)
Old 11-20-2011, 09:13 PM   #7
what VIPlumber said
Old 11-20-2011, 11:02 PM   #8
wraiththe's Avatar
Rewards Points: 91
Shower.
Funny about jacking up the house. Why not just wear platform shoes in the shower or use a step ladder.
Funny about the shower arm... I was using a water filter, shower arm and then head on a hose. The water pressure is low and it makes it hard to get all the soap off. Included a pic with the work done so far. The black line is 63" of tile, the green one is 73" of tile. Again the pipe is comming out of the wall at just over 83" off the floor. I was thinking about lowering it about 6 inches or so to below the bull nose tile If I tile to the lower line. That would be about 77-78" which is the height for a 6'3" person according to theory.
Old 11-20-2011, 11:47 PM   #9
Plumber
Rewards Points: 348
all joking aside, 78" is the rule of thumb as mentioned before. Whatever you decide, take into consideration the trim ring that goes on the shower arm. You do not want that have on - half off the tile.
bypass shower door height (Need more height!) KAdams4458 Kitchen & Bath Remodeling 14 10-30-2011 11:04 PM
bathtub rough in question: slip joint or glue pttcc Plumbing 2 09-16-2010 08:12 AM
Question about how to position backerboard for shower Swazzle Remodeling 3 08-03-2010 06:11 AM
Handheld shower in addition to fixed head OnTheGo Plumbing 4 03-25-2010 12:31 AM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 06:49 PM
