Old 01-06-2013, 04:32 PM   #1
Mommy DIYer
Question
Shower handles turned off but water still dripping
Super sorry for not knowing all the right terminology for parts, but I will try!
I have a double handle shower (1 for hot and 1 for cold). When I turn the water off (both nozzles turned as far to the right as they can go), the water still drips from the spout (or from the shower if I pull up the lever on the spout to start the shower).
How do I find out where the problem is?
Thanks so much for any advise.
kkmatheso is offline   Reply With Quote
Old 01-06-2013, 05:12 PM   #2
Plumber & Gasfitter
One of the O-rings in a cartridge has most likely broken and is now letting water through while the valve is in the "OFF" position. It may be the hot side or cold side, but cartridges are pretty cheap or even free (depending on manufacturer), so replace both of them.
joeplumber85 is offline   Reply With Quote
Old 01-06-2013, 05:15 PM   #3
Got a picture?
Going to have to shut off the water supply, remove the handles, remove the trim ring, then remove the valve stems so the washers can be replaced.
http://www.bing.com/videos/search?q=...pair&FORM=VDRE
Most will require a special wrench to remove the stem.
http://www.bing.com/images/search?q=...60DF1B&first=1
Old 01-06-2013, 05:21 PM   #4
Mommy DIYer
I replaced the valve stems last year. Do you think it is just the washers? I have extra black rings (looks like rubber washers) from that replace.
Old 01-06-2013, 05:22 PM   #5
Mommy DIYer
How do I add a picture? When I clicked on icon it asked for url
Old 01-06-2013, 05:35 PM   #6
Mommy DIYer
Question
I am trying to add a picture of the faucet...hope this works
Old 01-06-2013, 08:14 PM   #7
As old as that looks it may also be the seats that need to be ground or changed.
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 02:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 09:07 PM
