Old 07-31-2010, 06:16 PM   #1
Shower gooseneck turned
Hi,
I just put on a new showerhead. In the process, I used too much force when tightening the showerhead on the gooseneck pipe. The goosenect pipe turned a little, and I turned it back. The showerhead is ok but now my concern is if there is going to be a leak inside the drywall where the gooseneck connect to the water pipe since it turned a little, maybe an eighth of a turn. Should I be worried? Is the connection inside the drywall forgiving enough for slight turns?
jcnova is offline   Reply With Quote
Old 07-31-2010, 08:41 PM   #2
call me E
TheEplumber's Avatar
Its probably OK. Pull the trim plate away from the drywall, turn on the shower and shine a light on the shower arm where it connects to the shower riser. Look for a drip.
Old 07-31-2010, 08:55 PM   #3
Thanks for the prompt reply. I did pull the trim plate expecting to see a hole thru the drywall but the drywallers made it so perfect, there is no excess hole. I may have to cut a hole around it to see any drip.
I just don't have any idea how the gooseneck connects to the riser.
I'll live with it. In any case, when I turn the shower knob off, there should be no leakage. Or like you said, it's probably ok.
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bathroom shower surround StevePax General Discussion 0 11-12-2009 01:31 PM
New Shower Gooseneck issues banightingale Plumbing 2 08-20-2009 11:59 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
leaking shower gooseneck gator0625 Plumbing 4 06-16-2009 10:06 AM
