Old 12-11-2010, 08:53 AM   #1
Shower floor sinking
I have a one-piece shower stall, fiberglass I believe. We found a leak/crack in the floor and have caulked/sealed it - seems to be ok for now. The house is ten years old (we bought it 2 years ago). It seems as though they did a poor job of supporting the floor in this thing...it is squishy when walking in it. On top of that, the slow leak probably caused some rot in the wood beneath...my question is: Is there a way I can fix this without ripping out the whole shower unit and probably paying someone a ton? At front of the shower (under the door) the fiberglass goes all the way to the floor - so I cant "sneak" underneath.
joemontana16 is offline   Reply With Quote
Old 12-11-2010, 10:40 AM   #2
Have you ever heard the expression: "it is tough to polish a turd" ? I am afraid it might be appropriate in this circumstance. Unless you pay for someone to actually repair the fiberglass(not just caulk) it will probably continue to have a slow leak. And whenever I set a shower stall like that I set it in a mortar bed, which strengthens it significantly. It would be pretty difficult to address these issues without some serious work.
broox is offline   Reply With Quote
Old 12-11-2010, 11:26 AM   #3
no
plumberinlaw is offline   Reply With Quote
Old 12-11-2010, 12:10 PM   #4
www.No-Curb.com
JohnFRWhipple's Avatar
I have never heard good things about any one piece shower pan before. The irony with these pre made pans is people buy them to make things easier and in fact they can be three times as hard to install.
When installing a shower pan properly you need the same materials as when making a custom pan.
If it is sinking and squishing chances are that the framing was modified and/or poor quality thinset was used. These pre made shower pans are also very hard to waterproof where the shower base meets the floor.
Consider ripping it out and going the custom route.
Laticrete makes some great products for these types of repairs..
Good Luck
JW
JohnFRWhipple is offline   Reply With Quote
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 09:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bathroom shower surround StevePax General Discussion 0 11-12-2009 01:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
