Originally Posted by slloyd
The floor is a mosaic of fairly small non-skid tiles, approx 2" across. There does not appear to be anything other than cement or dark grey grout inbetween the tiles, and at the wall/floor joins.
The more important question is what's between the tiles and the subfloor? (I know, answering that question requires busting the floor up anyway..)
I thought there was supposed to be some kind of catch tray under the shower floor? Am I wrong?
You're right.. there should be a copper pan under the floor; then mud is laid on it, and then the tile. The drain fitting would be soldered to the pan, to prevent just the sort of thing you're describing.
There are other ways to do a tile shower (saw an episode of TOH a while back where Silva used styrofoam and a membrane to waterproof the shower), but a copper pan is the standard/best way,
AFAIK.
It's possible you have a pan and the joint with the fitting failed, or it's possible it was installed improperly. Either way that floor sounds like it's going to have to come out; sealing/caulking the surface might work temporarily, but eventually the ceiling will be wet again.
Err, but to second redline, pictures would be a huge help.. I'm just guessing there and don't really know what you've got..
