Old 03-03-2009, 01:16 AM   #1
shower floor install
I am installing a 60 x 34 walk in shower floor. Old tub had a right hand drain, the new pan has a center drain. Wondering if a right hand pan would be better as I have room to open the floor for more access where the trap is. Not quite sure how to tie everything together with the center drain, without really tearing up the floor. Hints, tips, and advice appreciated. Vito.
BTW....I'm pretty good with drywall so cutting a hole in the ceiling and working from below is a viable option......I could test for leaks before replacing and patching.
bikervic is offline   Reply With Quote
Old 03-03-2009, 07:08 AM   #2
If it had a right drain, makes sense from a work standpoint to keep it there. How the floor joists run would make a lot of difference in moving it to the center. Cutting joists requires that you reinforce them.
Old 03-03-2009, 07:59 AM   #3
Remodeling Contractor
look into Kerdi shower pan solutions. They even make custom drain locations.
Old 03-03-2009, 02:52 PM   #4
Gentlemen.....thanks for the replies. I won't have to cut any joists...they run parallel with the length of the tub / pan.
I did some looking around in the access hole and found that there is a drain pipe that runs parallel as well and it angles across just enough that the center drain would hit it. I have no choice but to exchange for a right hand drain pan. That settles that.
I will check out Kerdi on the web.
Thanks again. Vito.
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
Shower Arm Question brakea Plumbing 2 01-02-2009 06:58 PM
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 02:47 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
