#1 |
shower flashing
i installed a shower over a jetta tub (pompeno) and the city inspecter said i needed to install a flashing so the water would not run back to the walls. what is this and where do you get it thanks G
#2 |
Moderator
shower flashing
A shower over a tub? You need to provide us with much more information about the install. Pictures are worth a thousand words.
Flashing is an odd word for showers but there certainly is the need for a waterproof membrane on the floor and its transition to the walls. How that is done varies greatly. |
#3 |
Remodeling Contractor
shower flashing
flashing is a waterproof material used to direct water so that it does not penetrate into the wall (in this case) What is the walls above the tub covered with? You need a waterproof wall and it needs to lap over the tub edge (flashed) This is what he wants.
| Display Modes | |
| Backerboard under Fiberglass Shower Pan? | BillyDIY | Plumbing | 2 | 12-17-2008 02:47 PM |
| redoing basement shower - basic questions (relocating drain/options I have) | mslide | Plumbing | 5 | 10-28-2008 11:42 AM |
| very low shower head flow | rickard681 | Plumbing | 7 | 10-08-2008 07:43 AM |
| All shower fixtures loose, what to do? | darsunt | Plumbing | 4 | 06-06-2007 01:01 PM |
