Shower Flange Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2013, 04:55 PM   #1
Shower flange removal
My first shower remodel and have a question about the existing drain flange removal. I've cut out the 10 year old fiberglass shower and will be tiling using the kerdi system with kerdi drain. My question is what is easiest way to remove the existing drain flange that is attached (looks like it's glued)to the stub-up? can I cut the flange with a saw and then pry it off the stub or is it easier to simply cut off entire flange just below the flange where it connects to the stub? I think if I cut the entire flange off there should still be enough stub length to attach to the kerdi drain.
Trevor25 is offline   Reply With Quote
Old 05-12-2013, 06:54 PM   #2
Rewards Points: 582
post a picture of what you have ..sounds like pvc or abs,,.ben sr
Old 05-13-2013, 07:20 AM   #3
Thanks for reply Ben but for whatever reasons there's no "add attachment" on my reply window, so looks like I can't upload and post pictures. Also, In the small box at bottom of page it says "may not post attachments." I've seen other pictures posted so don't know why I can't?? Frustrating.
Old 05-13-2013, 02:53 PM   #4
i would cut the pipe a few inches below the existing drain and then you can put the new drain at the correct height.
Old 05-14-2013, 03:01 PM   #5
Thanks Danny. Much appreciated.
Old 05-14-2013, 04:59 PM   #6
DIY staff
Rewards Points: 7,174
I usually cut out the old P trap and then add a new ,clean , trap and riser----
removal of stand up shower jkoldhouse Plumbing 4 12-29-2012 08:46 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
How to remove soldered cap on my bathroom shower flange? ohman Plumbing 7 09-15-2012 12:08 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
glass shower door removal ross General DIY Discussions 1 04-25-2005 06:22 AM
